![]() | Home > Puma (Tdci) > Q: is it possible to get the MT82 gearbox out completely? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
it is possible to remove both at once considering you have the proper equipment and skills. Not recommended though.
As for the DPF can https://www.defender2.net/forum/post774875.html Puma 110" SW ............................................................. Earth first. Other planets later |
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 32 ![]() ![]() ![]() |
If it is done with the truck on the ground with a crane “inside” the cabine, I do not think removing both together is a problem. But why not unbolt and remove them seperately? I have only done it once and it just seemed easier to handle them one at a time.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17699 ![]() ![]() ![]() |
It's a problem at ground level because the assembly is too bulky to fit under the chassis. It's easier and safer to remove the transfer box first then the gearbox. If you have a lift you can remove them as a unit but unless bonkers you'll want to split them to inspect the adaptor shaft coupling anyway.
Ok, i did not account for the raised height of my truck. But anyway I would recommend doing them one at a time.
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
On Discovery 2 I have placed cca 20 cm high woodem blocks under all 4 wheels, than crane inside the cab and lower gearbox+transferbox together on a sheet of metal, to slide it out. Easy, just 2 people needed - first under the car and second to controll the crane. With car lift it is much easier now. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 200 ![]() ![]() ![]() |
Did this at -20°C. Wasn't that bad really. You'll need a good transmission jack for sure.
