![]() | Home > Off Topic > Quoting previous posts. |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Yeah - drives me maaaahahahaaad too ![]() But shout it at them in German because life is also terrifying and confusing... |
Whats all the fuss about ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
what? |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
Oh the mirth of it.
Absolutely hilarious chaps. ![]() |
I agree. The quoting of image heavy posts is utterly moronic. Other forums I use - if someone does that a moderator deletes the images in the quoted section and gives the person a ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Bobble thats a good point. I often quote the whole text when really its just a sentence within it thats relevant. And I do it simply because I don't know how to isolate a little bit of text.
You just quote the whole post then delete what you dont want to appear, like I just did with yours above |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Quite easy really,, so long as you leave the quotes in the brackets, both at the beginning and end ,, just highlight,what you don't want,, right click and cut !"! plus you can always put the item you mean in bold California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Started as a niggle, now its an education post
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
This is a test post to see if it works. ![]() |
Oh it does. Great. Thanks all. Cometh the hour etc...
