Home > Modifications & Maintenance (L663) > Spare Wheel Cradle & Hi-Lift Jack Mount
Sasquatch
United States 2016 Defender 110 Other SW Auto Fuji White
Installed the Spare Wheel Cradle & Hi-Lift Jack Mount from Safety Devices for my 48" Hi-Lift Jack X-Treme. Simple install, very sturdy, and well built. Used the Hi-Lift Running Gear Cover, Versatile Locking Knob (for security...had to get a different bolt than what came with the mount), and Handle Keeper (plus a few zip ties to keep down the rattling). I do have Lucky8's rock sliders so I got a RCI Lotus Slider Adapter (Rock Sliders Adapter for Hi-Lift Jacks)...it works great on the rails was very stable, when I tested it with the off-road base...also added a cheap Amazon handle grip to the jack and Lift-Mate so I can lift a tire and stack rocks if/when needed off-road.
The Spare Wheel Cradle is fantastic...really helps with re-mounting the wheel...definitely saves your back. However, the clearance is very tight...I am running 267/70R18 BFGoodrich KO3's (32.6") tires and that is close to the maximum size that will fit with the Spare Wheel Cradle & Hi-Lift Jack Mount installed.
PowerfulUK Install Video:
https://youtu.be/oA2eyAVwjzE?si=aGlzcY42vCNHJQAA
Below are the links to the products I used.
Safety Devices Spare Wheel Cradle & Hi-Lift Jack Mount:
https://www.powerfuluk.com/collections/new...ender-l663
Hi-Lift Jack X-Treme:
https://hi-lift.com/product/hi-lift-x-treme-jack/
Hi-Lift Running Gear Cover:
https://hi-lift.com/product/hi-lift-running-gear-cover/
Versatile Locking Knob:
https://hi-lift.com/product/hi-lift-versatile-locking-knob/
Handle Keeper:
https://hi-lift.com/product/hi-lift-handle-keeper/
Handle Grip:
https://a.co/d/04Kl0yp5
Lift Mate:
https://hi-lift.com/product/hi-lift-lift-mate/
Off-Road Base:
https://hi-lift.com/product/hi-lift-off-road-base/
RCI Lotus Slider Adapter:
https://rcimetalworks.com/product/lotus-slider-adapter/
Post #1038623 28th Jun 2024 12:35pm
Moo
Ukraine
Nice. I've been looking at this as well. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1038629 28th Jun 2024 1:51pm
