Home > Td5 > 1.4 to 1.2 Discovery transfer box
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Hi all, hopefully those that have done this can help, I purchased a Discovery 2 transfer box with the diff lock to put into my 90 TD5 and I just wanted to know if it's meant to be a direct replacement as when I went to change they did not look identical as such? This scared me and I bailed on the process Laughing
I am struggling to find a good tutorial / video of the process when changing to this transfer box
Any help / guidance appreciated
Post #1038544 27th Jun 2024 9:29am
rustandoil
Britanica restorations on Youtube ....
https://www.youtube.com/c/BritannicaRestorations
Post #1038547 27th Jun 2024 10:25am
They're not identical but are essentially interchangeable.
Disco2 has a larger diameter front drive flange (so swap it with the Defender one), due to the larger flange the front output casing is different (no need to worry about this), and round the back the speedo drive facility is missing from the Disco2 box since the Disco uses the ABS wheel sensors for the speed signal (so you'll need to swap the parts from the Defender box).
You will also find that the operating levers for the difflock and high/low selectors are different (I can't remember what the Def TD5 uses but the Disco uses cables no rods) and possibly the connectors for the associated switches differ.
So they are definitely not a direct swap, you will need to swap parts over.
Post #1038552 27th Jun 2024 11:41am
Dinnu
I replaced a transfer case on a later Puma with one coming from an automatic Disco 2 (if that makes a difference). I cannot remember the front out put flange as Blackwolf mentioned, but clearly remember that I swapped the rear output housing complete with the shaft that goes to the center diff and the high/low housing as the lever on the Defender is cranked with small ball joint.
There will probably be other sensors/switches on the Disco box which the Defender not use. Simply left unconnected.
Handbrake assembly kept the original Puma. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1038566 27th Jun 2024 2:41pm
