There is a wedge shaped clip in the center of the bottom of the antenna that you must hold and squeeze to lift the antenna up (after you remove the two nuts.). It’s not difficult just awkward. Clip is next to writing.
24th Jun 2024 8:45pm
Blake
Thanks for the quick reply! Do you know if the exterior cover only may be removed without removing the camera? I purchased a replacement cover from UK Powerful
24th Jun 2024 8:54pm
ThunderBob
I’m not positive but I do believe you have to remove it from the car. It’s really not that bad.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
