![]() | Home > Td5 > Alternator bracker adjustment |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 339 ![]() ![]() ![]() |
Hi, as far as I can remember the bracket bolts to the block with three bolts, two along the top, one at the bottom. The alternator locates to the bracket with one long bolt and there's a flat bar at the top. The belt tension is set with the idler, so you don't have to move the alternator to take up slack in the belt.
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 287 ![]() ![]() |
https://www.defender2.net/gallery/albums/u....26.08.png
So bolt "6" will i guess be at the bottom of the alternator. Support bracket (4) at the top, is the one i'm talking about. Havent touched the other ones, but i can only connect bracket (4) to either the alternator or the block, hence the push the alternator out question A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Yes, pivot the alternator about bolt 6 until you can secure bracket 4 to the alternator one end and the block on the other. Tighten bolt 6 and then the alternator should be in the correct place for the belt to be the correct length for the tensioner to do its job.
K thanks
The annoying thing is that you cannot buy the o-ring at the end of the Vac pump oil feed pipe by itself. You need to buy the whole thing at ~£80 Most expensive o-ring ever .... in terms of cost worse than the gauze filter behind the FPR I guess ! A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5930 ![]() ![]() ![]() |
Can you get some O-Rings from your local motor factors? 1999 Defender TD5 110
As said above I'm sure if you take the O-ring to a motor factor or a hydraulics wholesaler they'd match the thickness and ID of the O-ring without drama. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
Get the stainless pipe from Pioneer. Its half the price.
ok that's at least a 50 mile round trip to try and find somewhere but still good idea A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
If you search online you will find suppliers of o rings, if you have the dimensions to hand.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Everybody knows O rings only come in four sizes.
Too big Too small Too thin Too fat ![]() ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Would that not be “too” sizes???
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
