![]() | Home > In Car Electronics > Head unit fed from leisure battery |
falkster Member Since: 12 Nov 2023 Location: Sutton Coldfield Posts: 68 ![]() ![]() ![]() |
Thank you Mo,
just for me to understand, is the logic behind that, that any attempt to start would draw higher Amperes and therefore blow the fuse for the radio memory, therefore keeping the idea of the cut-off switch intact? If so, I'll have to be careful not to regularly blow the fuse myself... ![]() Thanks for your help. much appreciated. ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2290 ![]() ![]() ![]() |
Indeed. Buy a box of fuses 🤣 it let's enough power through for what you need but blows if you exceed the draw.
