Home > General & Technical (L663) > Flappy paddles |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 141 |
Simon at PowerfulUK has done it, I'm sure I've seen a YT video of it. You'd need the paddles and a steering wheel with the paddle recesses and also modify the CCF. Does this link help? https://www.powerfuluk.com/collections/new...ated-wheel Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
20th Jun 2024 10:01pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1394 |
I've fitted them myself but had to get them activated by David at Hunters as when I fitted them the IID tool was only on release G3, Patrick had said that if I waited for the G4 I would have been able to do it but I was too impatient.
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
20th Jun 2024 11:32pm |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1258 |
Cable ties and gloves..........🧐 Eiger Grey MY23 D250 SE with bits. Known as Noddy.
21st Jun 2024 12:42am |
David007 Member Since: 26 Oct 2022 Location: Angus Posts: 101 |
Cheers for that, but unfortunately they've not managed to find how to activate them yet. Last edited by David007 on 21st Jun 2024 6:34am. Edited 1 time in total |
21st Jun 2024 6:20am |
Cheers Ian, how are you finding the Alcantara on the wheel holding up? I really like the look of it but wasn't sure how well it would wear. As you fitted them yourself would you be able help and confirm what's needed, I'm guessing a new wheel and the paddles, however I've already got a heated wheel fitted so wasn't sure if I need the switch pack and wiring harness that are included in the kit sold by Powerful or not. Thanks |
21st Jun 2024 6:31am |
Hi, the wheel is holding up great it's been on there for just over a year and there aren't any visible signs of wear, it's even been covered in mud when off roading and it just brushes off when it's dry.
You will need the steering wheel, two paddles and I'm pretty sure the screws for the paddles don't come with them. If you already have the heated steering wheel you don't need the switch pack, at least I didn't, but you will need the harness as there are two extra electrical connectors, one for each paddle. In the Powerful video he shows taking the steering wheel bezel off to remove the airbag and wheel, if you have an auto adjusted steering wheel this is a right pain in the backside I actually managed to work out how to remove the airbag without taking the bezel off using one of these. Click image to enlarge Remember to disconnect the battery when working with the airbag Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
21st Jun 2024 1:28pm |
That's brilliant Ian, thanks very much. You don't happen to have the part number for the harness do you? spent a while going round in circles this morning trying to find the correct one. I've emailed GAP to hopefully find out if I can activate the paddles using the IDD tool. If so I'll probably go for the Alcantara wheel now after what you said
21st Jun 2024 1:39pm |
Off the top of my head no and I can't find the invoice for the parts, I did notice on the kit that Powerful supply they show the harness as LR142723 but I couldn't say whether that is correct or not. I suppose you could email Powerful and ask if that is the harness they used, but they are saying you need the switch pack and I definitely didn't replace mine so not sure whether I would take their word for it Cheers Ian
21st Jun 2024 2:57pm |
Thanks for looking and the information Ian. I've since had a reply from GAP and they don't know if the paddles can be activated so I'm going to put this one on the back burner for the moment.
21st Jun 2024 3:04pm |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 11 |
Hi.
I'm trying to fit paddles to my vehicle Model X D300 MY23.5 but still no luck. I have bought compatible steering wheel from Hunters and LR139904,LR139905 (paddles) and LR142723 (harness) from LR CENTRE. I believe that it is correctly parts. Plugged all connectors then activate two CCF items with G4 Gap Tool. MultiCAN-536 GearboxPaddlesInDrive MultiCAN-537 SWSGearSelectors Everything of switches works properly except paddles Any ideas? |
8th Jul 2024 2:18pm |
Sorry I can’t help, but please keep us informed if you find a way to do this
8th Jul 2024 6:22pm |
northeye if you want to send me over a copy of your ccf file I will compare it to mine and see if there are any notable difference. I'll PM you my email
Also are you sure that you plugged everything in, I know there was one very small connector that I missed on my first fitting Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Jul 2024 7:02pm |
Hi Ian.
I've just PMed my ccf. No connectors missed plugging I believe. Many times verified with watching PowerfulUK's YT. Both switch packs left one and right two, heater, 2 GNDs, blue one to bracket and of course small two for paddles. I'm worried that it 's not yet possible with the GAP G4 maybe. |
9th Jul 2024 2:27am |
Hello.
Since I checked the Live Values of TCM - "Gear Shift Paddle Status in Drive" and it was always disabled, I thought that CCF relearn is required for TCM maybe. So I did TCM-Module "Allow Central Configuration Data Learning" from the Service/Test Menu, but the operation was failed. The same operation for DADC was successful BTW. Perhaps the G4 tool is not (yet) possible TCM CCF relearn or something is wrong, I'm not sure though. still work in progress... Click image to enlarge Click image to enlarge Click image to enlarge |
15th Jul 2024 3:17am |
