Home > Maintenance & Modifications > LED headlight flicker...
falkster
Germany 1988 Defender 110 V8 Petrol CSW Trident Green
Hi All,
electrics this time, or rather head- and sidelights... 1988 One-Ten...
When I got my One-Ten it cam with the cheap'ish ebay LED headlight conversion. I ordered Stedi Homage lights, as they can be stickered for driving in Europe. whilst waiting for them I realised that my sidelights (is that what you call the little white ones in the front top corners?) where looking yellow compared to the white LED headlights. This sort of detail matters to me, so i got myself some LED bulbs for the sidelights and installed those, so that I can use them as DRL's. so far so good...
Once my Stedi's arrived and I installed them, i noticed that my headlights start flickering when I switch on the sidelights only (first click on the light switch). Not very bright, but a little bit like the blue lights on a stealth police car (only white in my case). If I go on the 2nd click on the light switch everything works perfectly fine (low beam and sidelights stable).
This Censored me, as I really would like to avoid always driving around with my headlights on, where the sidelights would really do.
Any ideas, why the headlights flicker, and more importantly, any ideas on how to sort this??
As always, many thanks for your input...
Post #1037874 19th Jun 2024 1:49pm
Retroanaconda
I suspect the dim-dip system is still hooked up and is providing a partial voltage to the headlights when the sidelights are on.
Post #1037907 20th Jun 2024 6:44am
discomog
Yes could well be the dim-dip system. The curse of the eighties. I'm sure if you do a search of the forum you will find details of how to bypass it. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #1037911 20th Jun 2024 7:27am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Simple enough to disconnect. The plug just needs to be pulled from the dim/dip module that is mounted inside the drivers side front wing, near to the radio ariel.
Jim
Post #1037912 20th Jun 2024 7:36am
Martin
Site Admin
On a 1988 the dim dip module is behind the instrument pack, and just requires the connector removing to disable it.
Source: me, has an 1988 90.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1037914 20th Jun 2024 7:52am
falkster
might be a stupid question, but what is the function of the dim-dip module, when it seems to be okay to just unhook it??
Wouldn't anything essential stop working?
Does it have a big sticker on it, identifying it as the dip-dim module?
And thanks for everyones input! Thumbs Up
Post #1038143 22nd Jun 2024 5:27pm
falkster wrote:
... what is the function of the dim-dip module, when it seems to be okay to just unhook it?? ...
This has been discussed many, many times in many, many threads before (indeed a search for posts with the words "dim dip" produces 33 pages of results)! I can do little better than to quote myself:
blackwolf wrote:
It is a useless feature which is optimised to make your headlight bulbs fail quicker!
It was actually a half-witted scheme by the UK government which meant that if you turned on the sidelights with the ignition on, the dip beam headlights would come on at about half power. It was for a short time in the late 1980s a UK legal requirement, until Europe, in a rare moment of sense, ruled that it was illegal under EU law for the UK to make it a legal requirement. So it stopped being a legal requirement!
Some manufacturers, especially those like Land-Rover, who thought the 1970s hadn't ended, went on fitting it for years before stopping.
Benefits of DD: none.
Disbenefits: running a headlight bulb on a reduced voltage has been shown to make it fail much quicker than running it on design voltage.
Post #1038147 22nd Jun 2024 5:57pm
discomog
Some more bed time reading:-
https://dastern.torque.net/techdocs/dimdip.html Defender 90XS SW
Morgan Plus 8
Post #1038151 22nd Jun 2024 6:56pm
falkster
Thank you blackwolf and discomog...
That's both very interesting reading. Coming from Germany originally I wasn't aware of those dimdip regulations.
Love learning stuff like this. So, thanks for your responses. Thumbs Up
Post #1038153 22nd Jun 2024 7:41pm
