![]() | Home > Puma (Tdci) > Removal of rear seats |
Taffy1 Member Since: 11 Jan 2017 Location: Bath Posts: 4 ![]() |
Hi Can someone give me instruction / tips for re ov8ngbthecrear seats in my Puma. Thanks
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 ![]() ![]() ![]() |
maybe here
https://www.defender2.net/forum/post620140.html Puma 110" SW ............................................................. Earth first. Other planets later |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1032 ![]() ![]() ![]() |
If this is the first time you've removed them and you want to remove the brackets too, make sure you have a set of blot remover heads for you socket set. You can be sure at the last bolt on each bracket will be stuck fast.
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 ![]() ![]() ![]() |
Did a video when I removed mine
Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
I hope it's 'bleeped' where necessary!
Don’t you hear the relaxing music that’s in the background 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
