- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Inguz
![](templates/vbnew/images/spacer.gif)
So I have a bit of spare time to get a few things sorted on the 110.
One issue that’s been bugging me and getting worse is an unusual vibration. What’s strange about it is that it’s most apparent in sand.
However it’s been getting worse on the road but usually happens when I’m slowing down and usually around 40 mph.
On sand it vibrates at all speeds and speeding up or slowing down.
It has a 40mm lift, wide angle front prop from Gwyn Lewis, super pro bushes, and cranked trailing arms.
7th Jun 2024 4:51pm |
Inguz
To add to this the vibration is gradually getting worse. However I’ve noticed that if I clutch or change to neutral the vibration stops.
16th Jun 2024 4:00pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
