![]() | Home > Maintenance & Modifications > Interior Lights |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8203 ![]() ![]() ![]() |
Mud one I have fitted has 3 way switch. Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20711 ![]() ![]() |
That’s interesting, only when I looked on the site it appeared to have markings on the switch as being two, or looked like a two-way due to the photo.
Perhaps I didn’t look at it close enough WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
2 of the Nak units in mine for the last 5-6years. Cant fault them.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 563 ![]() ![]() ![]() |
I have the Mud ones in my Td5 and love them, only issue I have is the red light in the front lamps is too bright for night driving so just use the rear red interior light.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5116 ![]() ![]() ![]() |
as an alternative to mud and nak, for those on a budget, these are fantastic and easy to fit take out the old bulb and replace it with the supplied one, they give a large bright pool of light available on eBay and cheap as chips.
![]() ![]() ![]() http://www.youtube.com/user/conwy1 |
Gilarion - Yes, I have seen those those SMD LED chips on eBay they are much better than any of the traditional LED’s.
Brighter and spread light better. I have similar to that now, only a little wide PCB panel with the SMD Chips mounted on it in the holder. They last a long time, I think they are 5050 SMD LED chips, mounted on a small rectangle PCB board, that fits the existing light fitting. They use way less power than the factory fitted bulb about 1/4 the power. I’ve used them on the interior light for many years now, never any issue at all with the AS10. If I remember rightly there is about upto 1A load available on each interior light circuit, more than enough for nearly everything LED interior wise. Just use behind the light @1A fuse in parallel to the switch contacts, for anything else and it will mirror the light switch settings and AS10 flawlessly without issue. Fuse then means everything is protected and if anything else should go wrong AS10 is protected and the interior light should also still be protected and active. If a fuse needs to be replaced just pop the light out and change it over, never needed to but fusing it is always the way to go. That’s what I do, adding extra old space light bars can be useful for some people. Lots of possibilities. ![]() ![]() ⛽️🛢️⚙️🧰💪 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
I have a Mud light in the original box somewhere and since a while I´ve become an anti led user by all means.
![]() ............................................................. Earth first. Other planets later |
That’s a point, it can be annoying different colour tones. WeWillWin🇬🇧🇺🇸
