![]() | Home > General & Technical (L663) > GaP 4 Daynamic mode |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1429 ![]() ![]() ![]() |
No, a few other people have had that where the dials don't turn red, it just seems to be hit and miss whether you get that. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Super3imi Member Since: 14 Jun 2024 Location: Kuwait Posts: 14 ![]() ![]() |
Do you think if i tried to activate it with another device or program i will get the red gauge? Cause its really cool and practical
I would say probably not, mine is a MY2022 and I originally had mine enabled with the Land Rover Pathfinder system and I didn't get the red dials, I have since tried with the IID tool and still no luck unfortunately
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1449 ![]() ![]() |
What's Dynamic mode? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 65 ![]() ![]() |
Basically Dynamic response changes the "map" of the steering and suspension systems to make the car feel more sporty. It won't be noticeable on a motorway as it is meant for sweeping bends and twisty roads that can be taken at high speed. The additional weighting of the steering and the firming up of the suspension are the most noticeable effects but the way it reduces the body roll is impressive on twisty roads. The difference between Dynamic mode and using S in the gear box is that S changes the shift pattern making the car hold onto revs right up to the point where if you haven't pulled a paddle to shift up then it will do it for you, Dynamic mode has no effect on the gearbox/ shift pattern
Thanks. Not sure I need it.
Thanks everyone for the help
I didn’t get the Red gauge but i got The Park assist working:) its a rare thing to get as i read . [/u] 22MY Defender 110 XS , Carpathian grey |
well done getting the park assist working especially on a MY2022
Yeah but i noticed that defender XS 2022 usa edition works . I dont know if it has different hardware than the other 2022 22MY Defender 110 XS , Carpathian grey
Ok, another question. What's parking assist? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Park assist have a read here
![]() https://www.landrover.com/ownership/incontrol/park-assist.html My 24 HSE X-Dynamic 90 Carpathian Grey |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
In my case instructions from the wife.. ![]() MY20 110 P400 SE Defender MY10 3.0 RR Sport |
