Home > Maintenance & Modifications > Power steering fluid return pipe
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Which pipe on a puma is the return so I can perform a fluid flush. Both appear to have high pressure fittings at the ends away from the reservoir
Post #1037214 12th Jun 2024 9:34am
rallysteve
The low pressure one will be the one which goes from the reservoir to the pump.
The return line will obviously be the one from the steering box back to the reservoir.
Post #1037216 12th Jun 2024 9:48am
