![]() | Home > General & Technical (L663) > 90 rear seat folding damage |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2959 ![]() ![]() |
Is it a sharp edge or just a flat piece of metal? lf it's flat you should be okay. But if it's a sharp piece surely there's something wrong with your build? l've not heard of anyone else with this problem and l am sure you would hear if it happened to anyone.
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3429 ![]() ![]() |
Yes I’ve noticed this on mine, next time I fold them I’m going to try a blanket over the seat base. 24MY 90 D250 HSE, Tasman Blue
San Marco Member Since: 18 Jul 2023 Location: Hesse Posts: 26 ![]() ![]() |
Thank you @J77, please let me know, if it works!
Cheers! |
Yes l was going to suggest a towel, or you could use a piece of high density foam (the kind that's difficult to compress) which would probably be easier to put in place.
Good idea @lightning! Thank you as well!
After all however, a bit disappointing though, that this issue seems to be normal, even more for they removed ISO Fix from passenger side front seat in fear of leather damages ![]() |
Do any 110 owners have a similar issue?
It seems they’ve fixed one issue but caused another. 24MY 90 D250 HSE, Tasman Blue |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 163 ![]() ![]() |
No. Rear seats fold completely flat in my 110, once the seat bases have been flipped up. Head restraints have to either be folded forward or removed first. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 136 ![]() ![]() |
No issues with the leather being 'dented', however the factory hd polystyrene underneath has got one bit of damage and I csnt tell where from. It looks like one the latch hoops has been pressed into it, but I can't work out how this could happen, unless the seat is physically removed from its pivot mount, so I suspect it happened at assembly.
2nd row seats fold perfectly flat, love it. |
