Home > Wheels & Tyres (L663) > New Range Rover 20” on L663
Cheshire110
Anyone know / tried whether wheels from the new RR/RRS fit on the Defender?
There are some quite nice 20” styles and they’re cheap as chips on eBay etc because all the drug dealers want 22s or 23s nowadays!
For example these, style 5125 I believe:
The tyre size is 275/55/20 which I think should be fine but I suppose the offset could be rather different or something? Cheers, David
Post #1036154 30th May 2024 11:55pm
BrickBox
I’d be stunned if JLR didn’t use the same stud pattern through the range. 2008 2.4 110 Utility Station Wagon XS.
Post #1036155 31st May 2024 1:16am
Cheshire110
Yeah I am sure the stud pattern is the same but the question would more be around offset etc potentially Cheers, David
Post #1036156 31st May 2024 1:36am
Fifth Horseman
Standard Defender 20" style 5098 wheel 41.5 offset
New RR 20" style 5125 wheel 43.5 offset
Puts the inner rim 2mm closer to the suspension knuckle then there is the extra 10mm or so due to the larger tyre (275 compared to the standard 255)
Post #1058583 25th Jan 2025 6:55pm
Grouse
They use different studs / nuts
Post #1061051 21st Feb 2025 7:51pm
