![]() | Home > For Sale & Wanted > [WANTED] TD5 Heritage/50th D90 twin tubed side steps |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2051 ![]() ![]() |
If my memory is correct, I don’t think the 50th anniversary Defenders had that style of side steps as in your photo.
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
![]() Click image to enlarge There is some on ebay in black with the plastic tread plates. Says they are for puma but will fit td5 no problem. I restored a heritage and got a set of these, removed the plastic treads and the heritage alloy plates fit perfect. I got them powder coated in the grey finish. |
Non UK 50ths came with them as standard |
Ahh, ok. 👍🏼
msns Member Since: 06 May 2024 Location: Yorkshire Posts: 3 ![]() ![]() ![]() |
Hi ginjez I have had a look at eBay and can not see the ones mentioned (can you send link). Unfortunately though I don’t have the original pair, they were discarded by the previous owner, so can not reuse them! I think they did come in a black finish also around this time for the td5’s. So I am happy with any finish, and can get powder coated. Cheers |
![]() Click image to enlarge These are the exact same steps on my 50th albeit without the cheque plate but I'm sure a sheet metal fabricator would be able to roll you some. The steps are available through britpart in black but make sure you fill the tubes with cavity wax as they rot out very quickly. I'd love to see more pics of Atlantic green heritage - it's my fave. |
