![]() | Home > Maintenance & Modifications > Going to 73mm from factory 95mm rear lights |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1137 ![]() ![]() ![]() |
The larger lights are mounted on a plinth, while the smaller lights fit right onto the body.
Everything is readily available in various degree of quality. Some butcher the situation by screwing cheap plastic fittings into the body work, leading to misaligned and unnecessary holes. Also absolutely no need to cut of the electrical connections, if they don't fit you bought the wrong lights. |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 ![]() ![]() ![]() |
So no plinth needed then.
Am I correct in thinking I won't have to drill new holes for the smaller lights? I want to avoid this at all cost of course. Thank you, P |
