Home > Maintenance & Modifications > 110 INTERNAL SLEEPING ARRANGEMENTS
Page 2 of 2 <12
Markeran
South Africa 2008 Defender 110 Puma 2.4 SW Keswick Green
Hi Peter
Does this mean you carry your RV4 on your roofrack?
Post #943046 19th Feb 2022 2:21pm
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
Hi Mark,
Yes it does, with three tie down straps.
Post #943063 19th Feb 2022 4:44pm
thebigreddog61
United States 1986 Defender 110 300 Tdi CSW Aintree Green
Hi Peter,
I know this is an old thread, but hopefully you will see this.
I was wondering if you could share what the edging is you used on the beds? Can I get the exact name of it as I am in the states and may have to do a cross-reference to find something over here.
Thanks so much,
Cliff
Post #1034665 14th May 2024 12:55am
trooper
Hi Cliff,
The ply edging around the beds is "T" section plastic edging, set into the ply with a cutter or router.
The beds, have various aluminium profile support structures to form a frame.
The "T" section plastic, light weight ply with both sides covered with a plastic finish, also the
aluminium profile support structure materials can be found in good caravan based stores in the UK,
maybe even, Amazon.
Regards
Peter
Post #1034687 14th May 2024 8:32am
thebigreddog61
Thank you for the information, Peter.
I really appreciate it.
Cliff
Post #1034725 14th May 2024 12:00pm
Page 2 of 2 <12
