Home > Maintenance & Modifications > Fuel leak
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Fuel leak
After a very expensive week... New exhaust, New UJ on propshaft, and a slipping clutch, Today I've noticed this fuel leak...
Any thoughts on where it might be coming from? I'm guessing top of the tank somewhere. I hvent filled up for a few days, and just been for a short drive.
No sign of leak where it's been parked so I'm guessing it's due to it being sloshed about
Post #1033795 4th May 2024 12:53pm
DAZ110
Fuel breather hose is usually the problem.
Have a read if all this:
https://www.defender2.net/forum/topic22296...ather+hose
I cut a hole in the floor similar to what is shown on page 8 of above link to fix my previous Defender leak. Rolling Eyes
Post #1033801 4th May 2024 2:26pm
Puma_Badger
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
Looks like the breather to me too. I got a garage to change both my breather and filler hose using genuine LR parts.
Post #1033802 4th May 2024 2:31pm
balmybaldwin
So I decided to have a little poke around, and a very rusty jubilee clip fell off. I have now replaced, and filled up with fuel, and no leak.
If only every landrover job was that simple!
Post #1034097 7th May 2024 6:14pm
You can get nice stainless ones of those if you find the size. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1034113 7th May 2024 8:12pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I was going to suggest checking the Jubilee's.
Learnt from experience to check them first.
Glad its fixed.
Post #1034156 8th May 2024 9:35am
revd
Removed my split breather last night, probably the original because the plastic clip tying it to the chassis was still in place, new pipe should arrive today - fiddly job to do in situ, but doable without dropping the tank (mudflap and wheel off, truck secure on axle stand) five minutes with a fine tooth sharp new hacksaw blade to cut off the old crimped clip on the tank connection, wrapped some gorilla tape round for a handle and used as a pull saw.
Post #1034162 8th May 2024 10:29am
DAZ110
I assume this was on a 110 ?
Think it’s more difficult on a 90.
Post #1034215 8th May 2024 6:49pm
revd
110 - still a faff
Avoid ‘marine’ reinforced hose, it’s not flexible enough if you are working in situ and stick with the standard type - don’t ask me how I know this. A flexible 1/4 drive is essential for the jubilee clip
Post #1034254 9th May 2024 5:39am
