Home > Td5 > wading plug in bell housing
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hi all I have been trying to find out about the location of the wading plug on the td5 bell housing.
I have obviously looked under the car and can see a large threaded hole on the centre of the bell housing at its lowest point.
It is about the same size as the oil fill hole on the transfer box. Is this the bell housing wading plug?
I had ordered a set of wading plugs that are much smaller than this hole? I can only assume that they may be from an older defender Tdi? Does anybody know the part number the larger one if that is what I need?
Any ideas appreciated
Thanks in advance Thumbs Up
Post #103351 29th Nov 2011 6:58pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
I'm willing to be corrected, but I thought the Td5 didn't need wading plugs (or already had them fitted, or something)?
Post #103352 29th Nov 2011 7:00pm
amondeggs
Im pretty sure that they are not needed on the engine due to chain etc but I think they are required on the bell housing?
Post #103353 29th Nov 2011 7:01pm
amondeggs
Right this may help Ive taken a photo of what I have tried to describe. In a nutshell is this the wading plug hole?
From what I have read online they are fitted at the factory but has mine been removed at sometime and not replaced?
Thanks again in advance Thumbs Up
Post #103373 29th Nov 2011 8:21pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I have a plug in that hole.
I believe this is the wading plug, but as you I would like to have it confirmed.
Most TD5 leave this plug in permanently, but I think it should be taken out to drain occasionally.
I haven't removed mine yet as I was never completely sure it was the right plug.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #103394 29th Nov 2011 9:25pm
bell-auto-services
Yes this is the plug/hole, and as stevie d said it does need taking out every now and then or leaving out when not off roading to let any fluids come out that may get collected over time.
Pete
Post #103395 29th Nov 2011 9:28pm
amondeggs
Thanks for that, I have not had the car that long and assume that it has been removed in the past and not replaced?
Going to do some potentially deep water this weekend and so want to get it plugged just in case.
Im am aware from what I have read that as you say normally the plug stays in apart from a check when the car is serviced.
Thumbs Up
Post #103396 29th Nov 2011 9:29pm
amondeggs
Thanks Pete that is a great help !!
Do you know where I can get a plug before the weekend Question
Post #103397 29th Nov 2011 9:30pm
bell-auto-services
I personaly and do do it the other way, I leave it out unless im going to get it in deep water, this way it will fully drain and never collect fluids or condensation and possibily contaminate the clutch over along period.
Ive seen many a clutch fail early due to contamination from water and or oil from the crank oil seal failing.
My 110 did the Dakar as a support/chase car from start to finish without one in at all and nothing went wrong Smile
Pete
Post #103398 29th Nov 2011 9:31pm
amondeggs
OK Pete thanks for the advice,
I would still like to get one just to pop in if I do have to cross deep water.
If anybody knows of where I can buy one from ( or has a spare they want to sell) Please let me know Thumbs Up
Post #103399 29th Nov 2011 9:35pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
I picked mine up from the local main dealer (for Tdi though, not Td5 but possibly the same plug). As an aside, does the Td5 only have one drain hole rather than two on the Tdi?
Post #103429 29th Nov 2011 10:44pm
markb110
Hi Amond
See your on the 10.30 session
i'll check in the garage tomorrow and will lt you know .
Mark
Post #103434 29th Nov 2011 10:54pm
markb110
Yes only one drain hole as the TD5 has a chain up front and not the rubber band of the TDI
Mark
Post #103435 29th Nov 2011 10:57pm
bell-auto-services
If you get stuck I think the part number is RTC4335, but if you visit any local nut and bolt shop its a standard thread type of which i forget the size, poss M14x2 pitch. just get any bolt and cut the thread down to 15mm and put a copper or fiber washer on it.
This is a good and very pratical short notice fix.
Pete
Post #103440 29th Nov 2011 11:07pm
amondeggs
Thanks for all the help I do appreciate it,
thanks for the part number Pete I will ring around tomorrow,
Markb110 it is a small world are you going the weekend in D3 or defender?
Post #103444 29th Nov 2011 11:30pm
