Home > Faults & Fixes (L663) > Vibration at highway speed |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Has the wheels been changed between left/right or front /rear to check for wheel (un)balance influencing the vibration?
As it only appears while steering right, I would suggest front left wheel bearing and/or stabilizers as a potential source. Has this been checked? |
13th Apr 2022 11:44am |
ehl Member Since: 19 Jul 2021 Location: valencia Posts: 4 |
I've left the car for couple of days at offical service and what they told me is that they've lifted the car and visually checked wheels, suspensions etc. They also told me that any poroblem related to bearings or wheel unbalance would manifest itself at all times and not as it happens to me under some certain circumstances. The only thing is the steering wheel was off center from the factory and they fixed it. How ever the problem persist after they fixed it as well. They've also cosulted to Land Rover internally if same happened to any other vehicle worldwide but no answer has been received. So I'm a bit stuck
13th Apr 2022 12:28pm |
Visual inspection instead of meaurements? And they had a couple of days for analysis?
Bearing problems manifest at all times? Well, yes, if you wait until they are completly worn and ignore early indicators. Sorry, imho your service told you . Your car is almost brandnew, keep repeating your claim until they solved it. |
13th Apr 2022 1:50pm |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1254 |
I have the same thing. I've had my car for four weeks and first noticed it on a trip to Milan on super smooth roads. It does it mostly up hill but I can change the effect with the steering wheel.
Did you get any resolution on this? |
1st Dec 2022 1:13am |
Hi, it took me long time any many debates with the dealer but finally they have changed the front left wheel bearing along with the part that holds the bearing and no more vibrations. Hope this helps.
1st Dec 2022 7:49am |
Thanks for that.
1st Dec 2022 9:14pm |
lints Member Since: 21 Oct 2023 Location: Johannesburg Posts: 1 |
I’m based in South Africa and have a 2021 D300 with 29000km on the clock. I seem to have a very similar issue. The vibrations are mostly experienced under hard acceleration or accelerating uphill above or around 100km. I haven’t notice any change when turning the steering left or right. I have had wheels and tires balanced and they seem all fine. Going to give the dealer a call tomorrow and get the car booked in. Hopefully it’s a similar issue and they can get it sorted fairly quickly.
@ehl, what was your final positioning with the dealer before they replaced the bearing? |
5th May 2024 7:00pm |
Mine 'healed itself'. Dealer couldn't replicate it and said everything was fine.
Not been an issue for 12+ months. Very odd though. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
5th May 2024 7:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20033 |
Grease the props and UJ’s, see if there is any difference, if there is then there maybe unbalance or an issue that needs looking into in more depth. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
5th May 2024 7:48pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 113 |
Was there not a recall some months ago for the bolts around the suspension, lower linkage comes to mind. Iirc the recall was that at factory, the torque was not sufficient. Have a search on here or other forums.
6th May 2024 1:08am |
6th May 2024 1:09am |
Can_glu Member Since: 18 Feb 2024 Location: Toronto Posts: 9 |
Could be some loose stuff stuck on the wheel, thus the wheel is out of balance and starting vibration. Once those loose stuff was shaken off the wheel, all are back to normal It happened to my car in winter time. Some snow got on my rim and there was odd vibration. After driving a couple of days, those snow were gone, so the car back to normal. So I learned. |
8th May 2024 3:16pm |
