Home > General & Technical (L663) > Speed limit warning - permanently turn off? |
beeftinkler Member Since: 13 Apr 2024 Location: Truro Posts: 31 |
Does anyone know if Hunters can do the Driver Assist modification remotely (6hr drive from Truro to Thetford )?
13th Apr 2024 8:48pm |
Damn. Does anybody know anyone in the South West that can update the Driver Assist to save the last setting (low)?
30th Apr 2024 7:13am |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 20 |
Answered in the other thread https://www.defender2.net/forum/post1033785.html#1033785 |
4th May 2024 11:27am |
As stated, Hunters are 6hr drive away. I’m looking for someone in the South West of England.
4th May 2024 11:30am |
Sorry, I just meant I think I've figured it out with the G4
4th May 2024 11:31am |
Ah! What’s a G4?
4th May 2024 11:43am |
It's the device from GAP Diagnostic that lets you change the settings on the car.
It's around £500 so maybe not worth it if you only want this one thing. I'm sure that as more people get this figured out there will be someone local to you that can change it. |
4th May 2024 11:50am |
Sounds great, and I'd be happy to co-purchase with others on here. I'm also looking to re-map our D250 to D300 if that's possible with a G4?
4th May 2024 2:26pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1394 |
Id just buy one and have done. You'll be surprised how much you actually use it. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
4th May 2024 9:54pm |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 57 |
Wow! Sounds promising. I will try it with the G3. Edit: No luck. Doesn't even show up in my CCF. Hoping its because I use a G3. Will upgrade to G4 but awaiting new car so no rush. 2025 Defender 130 V8 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
6th May 2024 10:25am |
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 33 |
To disable TrafficSignRecog: MultiCAN 742: from "TSR Fitted with OverSpeed" to "TSR Not Fitted" |
13th May 2024 5:44am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2825 |
You can't with the GAP tool as it's locked to one vehicle unless you pay £2,000 for the professional version. |
13th May 2024 7:54pm |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 97 |
You could purchase an extra vin. That is cheaper than buying the whole IIDTool
14th May 2024 4:31am |
