Home > Puma (Tdci) > Yearly service 2014 2.2 puma
Page 3 of 4 <1234>
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Brilliant info. At least I know where to look. Once my grease gun arrives I’ll need something else to do!
Post #959905 28th Jul 2022 10:04pm
spudfan
Ireland
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #959907 28th Jul 2022 10:36pm
Dinnu
^^^ except that later Defender prop shafts do not have a grease nipple on the sliding joint, marked as 2 above. The only grease points are in the UJs. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959913 29th Jul 2022 6:33am
pilsburypie
Well that was a big disappointment. Got my grease and my piston type grease gun and expected to pump fresh grease in the props and see it ooze out showing it’s freshly packed.
But only 1 out the 4 seems to take the grease. How do the nipples work? Seems there is a small ball in the middle? Is it sprung? Does the grease pressure over ride this and let grease in? Is it possible my nipples are blocked/stuck? Shocked
Any suggestions appreciated. Balls deep in this maintenance now and can’t be doing with non greased props!
Post #960046 30th Jul 2022 5:13pm
Dinnu
I cannot get my grease gun to fit properly on the prop grease nipples so I remove them to grease.
Yes, the grease nipple has a ball (non return valve). The grease gun is able to build enough pressure to push the ball and grease in. The ball should return out to keep the grease in.
Edit: I remove the prop shafts not the grease nipples!! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #960051 30th Jul 2022 7:40pm
pilsburypie wrote:
...But only 1 out the 4 seems to take the grease. How do the nipples work? Seems there is a small ball in the middle? Is it sprung? Does the grease pressure over ride this and let grease in? Is it possible my nipples are blocked/stuck...!
This is a common problem and usually indicates that your nipples have been neglected and the grease in the uj has dried out and gone hard. Unfortunately this also means it is no longer lubricating.
There are impact greasers available which sometimes can blast the blockage out but generally they don't work well on ujs due to the multiple grease paths.
If you are really lucky unscrewing the nipple and cleaning both it and as much of the congealed grease from the uj spider as you can may do the trick, sometimes injecting oil rather than grease can do the trick (regrease afterwards, of course).
More commonly with a really bunged up uj the only option is to remove the uj from the propshaft, dismantle it completely (caps off, rollers out), clean and grease everything then reassemble. If you're adept at whipping ujs out this only takes about an hour per prop including removing and refitting the propshaft. If you're not, allow a day and make sure you have a couple of spare ujs just in case.
Post #960057 30th Jul 2022 9:10pm
pilsburypie
Thanks for the replies. Think my first port of call is going to be to see if I can push the little ball in…. Then see how easy it is to remove the nipple. Then start planning prop removal which I’m not keen on.
Path of least resistance first I think.
Post #960061 30th Jul 2022 10:43pm
kenzle8a
Prop removal isn’t bad to do, I’ve done it when it was so cold my spanner froze to the prop.
Post #960062 30th Jul 2022 11:05pm
spudfan
Ireland
Is it any wonder people regard us Defender owners as a bit "odd". Me, I'm very odd and proud of it. Mr. Green 1982 88" 2.25 diesel
Post #960063 30th Jul 2022 11:09pm
458GT
Laughing perhaps you are right!
But alas it's what makes the owner clubs perhaps.
Very useful maintenance refresher - thank you!
Post #960065 30th Jul 2022 11:30pm
spudfan
Ireland
Nobody has mentioned wearing suitable head protection like cyclist or cavers. I have lost count of how many times I have hit my head on various bits of Land Rover paraphenalia while working underneath it. Fair enough it does not damage the Land Rover but it does keep my stock of expletives in use Mr. Green 1982 88" 2.25 diesel
Post #960283 2nd Aug 2022 9:46am
There is a good reason for not wearing a hard hat or similar - generally the Defender is harder than your head, so suffers no damage if you whack your bonce on it. Damage to said bonce generally heals with time, sometime leaving minor scars to add that look of rugged wild-eyed mystery that Defender owners tend to have.
If you wear a hard hard there is a good change that the noggin will be fine but the vehicle will suffer. That means expensive repairs.
Next time you hit your thumb with a hammer, be happy that your thumb has saved damaging something that isn't self-healing!
Post #960293 2nd Aug 2022 12:11pm
The Zee
^ Rolling with laughter Rolling with laughter Rolling with laughter Zaid-M
www.DefencePhotos.com
Post #960591 4th Aug 2022 9:09pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
I found this video helpful for greasing mine.
I bought a set of longer grease nipples as advised, just in case, but didn't need them.
Something like this, which can be temporarily swapped out for greasing only.
https://www.ebay.co.uk/itm/233642984589
I had 5 grease points on my propshafts 4 on the UJs and my front propshaft has a grease nipple but the rear one doesn't.
I checked it thoroughly in case the nipple was missing but it is a solid shaft. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #960667 5th Aug 2022 2:25pm
Naycrx
How much grease do you pump into the prop shafts? Ie does it come out anywhere? Th UJs I can see it coming out of ...but not the prop
Post #1033566 2nd May 2024 5:38am
Page 3 of 4 <1234>
