Home > Puma (Tdci) > Bent Door Switches - Alarm Woes
Dorothy
Vehicle was shouting at me when I went to lock it. Checked the door switch and it was bent over inwards, so circuit was not closing when the door was shut. I swapped in a spare from the TD5 with a longer button but notice this bent over straight away too. Checked the passenger side and... yep bent over.
All seemed fine and just suddenly both are knackered. Assuming this just the usual engineering failures rather than something Machiavellian.
Alas, the alarm went off earlier which was quite distressing.
Is this a door aligment issue? I have new switches arriving tomorrow but just wondering how I can ensure tonight she is alarmed and unlikely to throw a wobbly at 3am. I don't appear to be able to central lock her without the fob. If I push down the button internally it just pops up. Lock barrel is knackered too.
I have a donor vehicle for more switches... 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
2013 Defender Puma Utility XS
Post #1033543 1st May 2024 6:41pm
It might be the brackets that activate the switches, are they bent or loose? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1033544 1st May 2024 6:45pm
Dorothy
Checked them and they look solid. No cracking or movement. The front lower hinge is shot which may mean it was catching it. I have bent them back, turned them through 90degrees so they bend outwards towards the door plate. Should suffice until morning.
I think the alarm went off because the button wasn't held behind the plate and slowly crept back out, suggesting the door was opened while armed.
I wonder if just removing the knackered buttons would keep the alarm happy?? 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Post #1033550 1st May 2024 7:21pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
"I wonder if just removing the knackered buttons would keep the alarm happy??"
Yes. Just unplug them. The switch is open when the door is closed. Easy to remember Laughing
Post #1033628 2nd May 2024 3:46pm
Dorothy
Cheers. The olay in the door due to a broken hinge is causing the striker plate to come in at an angle. I have three left of the aftermarket replacements which are made of a more brittle plastic. No give at all. 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Post #1033786 4th May 2024 10:30am
