Home > Faults & Fixes (L663) > D250 Engine Oil Leak
ddg333666
Australia
Hi guys
My Defender 110 250D (2021) having below oil leaking issue . Is this something serious or could be an easy fix? Car is currently at the Dealership. Thanks in advance
[/img]
Post #1033468 1st May 2024 2:55am
DFNDER
Australia
Diesel engine oil will stain everywhere, it's so thin and black. Looks like the turbo oil feed line or fitting is leaking. Any oil underneath the vehicle? That could suggest turbo main bearing seal...
Post #1033481 1st May 2024 8:44am
ddg333666
Australia
Luckily no oil underneath , JLR return the vehicle and advised turbo oil feed was loose, let's see if happens again . Thanks for the reply
Post #1033568 2nd May 2024 6:50am
lightning
The turbo oil feed pipe has always had slight leak on my D250, l've looked at two others and they were the same.
l would take it back to the dealer, but in my experience they usually make things worse, plus the last time it went in for a recall it came back with scratches from shoddy valeting.
Post #1033643 2nd May 2024 6:13pm
