![]() | Home > General & Technical (L663) > Adblue filling limit |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2954 ![]() ![]() |
l've not heard or read anything to this effect.
But to be on the safe side just do what he said. My D250 uses so little Adblue that l will probably only have to fill it twice in five years of use. Currently l am on 11,700 miles and it's still saying there's 6,000 miles before it needs refilling. |
Huwrhys Member Since: 27 Mar 2024 Location: Hornchurch Posts: 134 ![]() ![]() |
I bought my 8 month old 130 with 9650 miles on the clock and it says it’ll take 2 gallons (9lts) so I wonder if it was ever filled up.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2656 ![]() ![]() ![]() |
With Wifey's Velar i wait until the Remote app says that it needs 11 litres. I then buy a 10 litre bottle from Halfords or Amazon (depends which is cheaper at the time) and put it straight in.
No need to measure, use the lot. On her previous D Sport with the service package Adblue top ups were free, however it was a pain because it was time out of our day plus a half hour wait for something that i can do on my driveway in five minutes. They did say at the time that their fancy machine measures the exact amount and stops over filling, but if you do what i do its no issue. If i remember correctly they were charging £36 at the time outside of a service contract. Add in your personal time and it just makes sense to do it yourself. |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 165 ![]() ![]() ![]() |
Check the capacity! If its more than say 12l…
Then wait for the first warning, put 10l in, simples Just remember it takes up to 40 miles or so for it to register and the warning to go! |
I have indeed refilled my own ad blue on my FFRR on many occasions, but I’ve always filled it to the top without incident. The question I was asking was is anyone aware of overfilling causing a problem on the defender L663? I use a pump to fill my ad blue tank and it’s an easy job to find a container and measure out the literage I need less 1L. I wanted to know if anyone else had been told the same. 24MY D300 130 X-Dynamic HSE Santorini Black
Will any Adblue be okay or is there a specific one that we are supposed to use?
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1444 ![]() ![]() |
Any Adblue is fine.
In 26000 miles I've added 10 litres, although I think LR added some when it was serviced. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
