Home > Technical > Defender TD5 Grinding noise when turning slightly left VIDEO
charliebroom
United Kingdom 2014 Defender 110 Puma 2.2 SW Fuji White
Hi,
My Defender TD5 has a grinding/whirring noise when turning slightly left (Nothing when turning right) it sounds like a stone caught between something and stops when on full lock or with the wheel straight... Only happens at 5-15MPH then goes, I can see anyting grinding and it dosn't do it when stationary, heres a video, the audio isnt great.
https://youtube.com/shorts/sEa-7jRWYUI
Post #1032807 25th Apr 2024 2:04pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
The easiest first check is to take the cap off the drive member and check the CV joint splines are greased. If rusty, they can grind and bind as they move in and out when turning LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1032835 25th Apr 2024 7:13pm
landy andy
Check for debris stuck between brake disc/brake calliper/disc back plate.
Post #1032874 26th Apr 2024 4:15am
landy andy
Post #1032875 26th Apr 2024 4:15am
