Home > Td5 > TD5 (2004) Coolant Loss |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Usual culprits are:
- Cylinder head blanking plug (you wont have one any more as AMC heads dont have the casting), - Heater matrix (often a small leak is not visible but you can often smell coolant via the heater from inside), - Fuel cooler on the side/underside of the inlet manifold (the cylindrical ones have o-rings in each end which can let coolant drip), - Radiator corrosion (normally can see dampness at the bottom of the radiator but partly obscured by the intercooler, - Water pump (there is a weep hole on the underside of the casting which will show you if the seals are failing), - Coolant outlet at the front of the head (these often corrode around the hose jointing surface and drip coolant onto the PAS pump/water pump housing beneath). My Td5 has never allowed the coolant to remain at the 'MAX' mark on the tank. If i fill it upto the mark it always drops 10-15mm below that on the next run but never drops any lower. Hope that helps Steve 02' 110 TD5 Double Cab Rebuild Thread |
22nd Apr 2024 1:54pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1631 |
it could be any one of number of things on a td5. easiest way is to pressure test the coolant system when static for visible leaks. could be as simple as a pressure cap failing.
if you dont find anything coming out it points towards it going into the engine so then you can move on to that side of things we a sniff test or similar. assuming the oil is free of water? and level has not risen |
22nd Apr 2024 1:57pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
thank you.
Will start with all the points set out by rallysteve. thanks Mdm. I dont have the equipment to pressure test the system and no water in the oil but will take board your points as well. Thank you both . Duncan |
22nd Apr 2024 2:01pm |
I do smell coolent so could be the heater matric.
I wonder how much a new one is!!!!!!!!!!!!!! |
22nd Apr 2024 2:02pm |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 223 |
I had coolant leaking out from around an exhaust manifold stud🤷♂️
24th Apr 2024 1:27am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 |
If you can smell coolant, I’d definitely look at the expansion tank cap. It sits right in front of the driver (RHD), so you’ll smell any leaks from that area. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
24th Apr 2024 5:35am |
Ok will have a look but it does look clean.
Thanks Duncan |
24th Apr 2024 4:21pm |
For anyone interested, it looks like it was due to the failure of two clips on the plastic T-piece that connects to the thermostat housing and also the pipe from the header tank. Two of the clips had rusted and snapped so that when the car got hot the pipes expanded and leaked coolant, when cold they were fine.
So, replace the clips and let's see what happens. Thanks again for all the advice. Cheers Duncan |
30th Apr 2024 2:43pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Glad you got it sorted.
It’s often difficult to trace these issues. Fingers crossed that’s the end of that 👍 |
30th Apr 2024 7:12pm |
