Home > Puma (Tdci) > Puma 2.2 Compatible Oils
Page 5 of 5 <12345
Dinnu
Ianh wrote:
The Penrite oil site provides a good insight into the ACEA standards. Including C1 is Sulphated Ash <0.5% , and C3 is Sulphated Ash < 0.8%.
These percentages are small, however in comparison C3 would potentially have 60% more sulphared ash than a C1, which would not be good for a DPF.
https://penriteoil.com.au/knowledge-centre...ations/364
That indeed is very informative Thumbs Up
The thing is that the more I read is the more seems like that the C1 protects the dpf and to certain extent the environment more than the engine. And engine failure is not cheap either.
Very confusing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032584 23rd Apr 2024 7:24pm
Ianh
I think you sum it up perfectly, hence my strategy to balance things up is to use C1 oil to protect the DPF but change Oil every 5K miles or less to protect engine.
Post #1032591 23rd Apr 2024 8:22pm
Jimbob292
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Zambezi Silver
Wise choice, the engine will thank you for it.
Looking for my oil change at the end of summer, anybody had good or bad reports on the below oils ?
PETRONAS Syntium 5000 FJ 5W-30 Fully Synthetic Car Engine Oil
or
RAVENOL FLJ SAE 5W-30
Both meet the LR/Ford spec WSS-M2C934-B
Post #1035712 26th May 2024 4:54am
Mike2a
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Smith & Allen
Hi all
What would the the recommendations be on this for my 2.2?
https://www.smithandallan.com/product/smit...e-oil-4127
It meets the correct specs, I have used them for my series but that's a bit more accomadating to differing gardes of oil.
Cheers Mike
Post #1035876 28th May 2024 9:36am
Ianh
Hi Mike, My basic assessment.
Looking at their site the oil does meet the correct spec for 2.2 with DPF.
They have been around since 1925 and have quality measures in place to ensure they meet the specifications they state for their oil products.
The price looks good, especially if you purchase 20L. However I can’t see the delivery costs.
You have bought their oil for you series and are happy with its performance.
So it looks good to me, even more so if you intend to change the oil every circa 5k miles as I do.
Post #1035889 28th May 2024 11:52am
Mike2a
Thanks for the the response ian. I was certainly happy withe the ep90 in the series before I detonated the gearbox for the 3rd time. Not an oil issue but a over gearing and weak 3rd gear.
Post #1036037 29th May 2024 9:37pm
keith
Iv had a new LOF clutch fitted last week. Whilst both boxes were out I replaced both with EP90. I can tell that it’s thicker but Gear change is tight and quiet.
Post #1038483 26th Jun 2024 4:36pm
Page 5 of 5 <12345
