Home > Puma (Tdci) > Defender 2.4 TD4 don't start
Page 2 of 2 <12
xmotor
France 2011 Defender 90 Puma 2.4 CSW Barolo Black
thanks for your reply.
I have bought the TD4 interface in january but i haven't got this position. I have asked Nanocom to send me the last version of TD4 interface. I wait his answer.
Post #1027362 9th Mar 2024 8:16am
xmotor
Hello,
I have uploaded the new firmware of the nanocom and i have now EMS SYNC. But when i use EMS SYNC for the defender 2.4 TD4; I have the message " FAILED TO SYNCHRONIZED 10AS ALARM"
I think I have injection cutt-off and I want to know how to do ?
Is there a procedure for setting up the ECM? Is it the alarm box that shuts off the injection?
the engine only cranked with startpilot.
Post #1031223 10th Apr 2024 9:03pm
Have you synced the fob first? Needs doing every time battery power is disconnected to re-sync it. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1031226 10th Apr 2024 9:37pm
xmotor
The fob works. The remote control opens and closes the centralised doors and activates the alarm when it closes
Post #1031247 11th Apr 2024 7:50am
xmotor
Hi everyone. Still with my Defender 2.4 TD4 that won't start after an engine, turbo and injector replacement.
In NANOCOM, When I set "MEMS FAILURE INDIC" to ENABLED in the settings2 of the ALARM 10AS menu, it puts the red light on me and I can no longer turn on the starter. If I put DISABLED I can run the starter motor but I still have my injection cut-off active. Who's got an idea? Is my ECU immobilized?
Post #1032456 22nd Apr 2024 7:38pm
andy63
Do you have a inertia immobilisation switch and if so checked the eiring๐Ÿค”
Post #1032464 22nd Apr 2024 8:00pm
xmotor
No
There isn't inertia switch on his DEFENDER 2.4 TD4 model.
Post #1032481 22nd Apr 2024 9:25pm
Ianh
xmotor wrote:
Hello,
It does seem that the 10AS De-mmobilisation code is not getting to the engine ECU. You said you removed pins 3 and 4 from the ipac connector, so double check it was pins 3 and 4 . Iโ€™m assuming they are no longer in the connector.
You should also check the wire from the 10AS connector to the ECU connector for continuity.
Also check all the 10AS related fuses.
Post #1032489 23rd Apr 2024 1:19am
Page 2 of 2 <12
