![]() | Home > Technical > Type of injectors |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 635 ![]() ![]() |
Types of injectors?
From reading my workshop manual I had always assumed my injectors on the 2.2tdci engine were electro mechsnical/solenoid type.. Information passed on in conversation with some folk led me to check the resistances of my injectors which all came in at about 200Kohms.. That definitely indicates piezo.. I was also checking or playing with the scope and using a current clamp and inductive pick up on the same injector.. The lowish actuating current I'm told also points to a piezo.. So just looking for final confirmation from folk who know about these engines that they are in fact fitted with piezo injrctorsš¤ And just for info I had a zoom in on one of the traces of a firing event.. Even at tickover you can clearly see 3 stages of injectionš ![]() Click image to enlarge |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2152 ![]() ![]() |
Iām pretty sure you are right Andy.
I believe our 2.2 injectors are Siemens/VDO part number 2910000177400 and if you read page 6 (says page 4 on the actual document ) of the linked VDO document it states Common Rail Diesel Injector Our piezo servo injectors ensure extremely precise injection and ultra-fine atomisation of diesel fuel for highly efficient combusā tion. Direct-drive piezo injectors make it possible to achieve greater fuel efficiency in powerful engines. Then on page 10 (says page 8 on the actual document) you see details of the Siemens/VDO part number 2910000177400 injector and it states itās for our 316 Pumaās. It does not state itās for the 2.2, but then the 2.4s donāt use Siemens injectors. https://www.vdo.com/media/747131/vdo-catal...7_2019.pdf PF Jones site also confirms the VDO part number is correct for our 2.2 Pumaās. https://www.pfjones.co.uk/land-rover-defen...77400.html |
Cheers Ian... That's great.. I never even thought to have a close look at the injectors to see if they had any identification marks on them.. Will have a look today..
Thanks agsinš |
I've had a look at my injectors Ian.. There are markings on the top that can be seen if you have decent light.. They seem to be marked FMCo.. And what I'm presuming is the code for that injector.., š |
Great info
Cheers ianš |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
I am really curious how the waveform change with load. ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
hmmmmm....curiosity....not sure I can remember what that did.
