Home > Puma (Tdci) > Puzzled |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
sounds fuel related.
low on fuel? bit of water in there?? |
28th Nov 2011 10:31pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Not low on fuel, had about 40 litres in tank.
Have topped up since the episodes. Brendan |
28th Nov 2011 10:35pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Could have been water in the fuel. Might be worth running a can of wynns dry fuel through it.
28th Nov 2011 11:25pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
A few options, as said already... fuel...water or dirt ingress, check filter. Check vent pipe also.
EGR maybe if MIL light came on? We had one in that just lost power, it was like it was in limp mode, then ran ok, then went in limp again, that was a duff intercooler hose ! |
28th Nov 2011 11:36pm |
maybe a bad fill up somewhere, i'd put a tank of ultimate diesel in before you take it on a long run, it cleans the pipes, pumps and injectors. i don't use it every tank, probably 1 in 4 but it's good stuff.
also check fuel filter for water ingress |
29th Nov 2011 7:38am |
