![]() | Home > In Car Electronics > TD5 Console Conversion |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 492 ![]() ![]() |
SP panels do a facelift TD5 type dash conversion
Check out Mudstuff.co.uk they do what you need.
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 334 ![]() ![]() ![]() |
Fitting the Mud double DIN is fairly straightforward, but obviously requires some dismantling. Take photos as you go just in case.
When I changed the console to the double DIN, I also changed the binnacle Mount, because the original was cracked and barely holding together! Raptor sell a metal binnacle mount that is much stronger than the original plastic one. Raptor also sell a metal binnacle end plate, but I have no experience of this. |
They only do the centre panel the op needs to convert from a early 300tdi dash |
