- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
keith
custom90 wrote:As BW mentioned just above. Also, driveline slop in the rear can cause a lot of these things and worn bushes.
This causing a lot of movement an less precise feel to the clutch bite meaning it’s taken up more harshly than expected, possibly with a slight torque reduction with the clutch switch.
Wearing heavy footwear is something to bear in mind as well, on a Defender you don’t want too light, but not too heavy either.
Yes, the pedals are fairly large but all the same the feel is limited and more harsh on driveline.
+1. Perfect description
27th Apr 2024 1:53pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
