Home > Wheels & Tyres (L663) > 20” L322 Range Rover wheels on a Defender? |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 142 |
L322's have a much greater positive offset - like 2cm worth - than the L663. You'll need to run spacers. Depending on the wheels I'd look at 25mm or so. But you'll also need to make sure the overall tire diameter is close or, in the case of a flat, you'll be risking much more than the cost of a stolen wheel after only a few miles.
RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
20th Apr 2024 12:02am |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 215 |
Ok. Thanks for the info. I’ll not bother investigating any further MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
20th Apr 2024 9:28am |
