Home > Technical > Adding Electrical Accessories
Page 2 of 2 <12
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Two choices
https://www.mobilecentre.co.uk/blue-sea-st...holder-box
https://www.mobilecentre.co.uk/blue-sea-st...er-box-kit 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1031744 16th Apr 2024 8:58am
Dorothy
The bolt on the Negative terminal is alas too short to take the Earthing block, so I guess I have three choices:
1. Find a longer T bolt to allow extra hight to attach the earth block direct. (Sitting with a file, bench grinder etc for half an hour doesn't appeal right now...) Cool
2. Fit a flatter ring connector spur and then connect the earth block to that. They are thinner than the Blue Sea block.
3. Change the battery connector cable to something more flexible.
I probably need to look at my main earthing points anyway as she doesn't start instantly.
 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
2013 Defender Puma Utility XS
Post #1031838 17th Apr 2024 10:42am
mcma1
I guess I will face the same issue when mine arrives in the next day or so Confused Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1031873 17th Apr 2024 2:13pm
Dorothy
The first stage was fairly straightforward. Fits well now I have swapped the connections on the Positive terminals.
For the time being I've added a Halfrauds spur to the top of the connector. It is an M6 bolt, a nut may complain at the top of the thread but goes on securely.
Rather than rush it I have temporarily mounted the negative block with some cable ties to the battery handles.
Gives me time to have a think. Of course you could just fasten the earths to the ring...
DRLs are once again running. Gives me a chance to figure out why they had been disconnected!
Now to think about best cable routes from engine bay to battery box. At present for testing they come in through the passenger footwell.
The typical Puma battery connectors need to be loosened and then tapped down with a socket or flathead screwdriver and small persuader before you begin to tighten them. 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Post #1031909 17th Apr 2024 6:23pm
Perhaps take the ground from the chassis rail factory ground point, then back up, and mount on seat box wall?
Or use a different ground clamp, with multiple outputs and then mount on the seatbox wall.
As itโ€™s a ground you could use a super strength acrylic adhesive pad if you didnโ€™t want to affix it permanently.
Just a couple of ideas, not sure if these suggestions are any use but the factory ground clamp is a fickle thing. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1031913 17th Apr 2024 6:49pm
Page 2 of 2 <12
