Home > Td5 > Defender TD5 cruise control.....confused!
Page 5 of 5 <12345
Bim
United Kingdom 2005 Defender 110 2.5 TD XS CSW Tonga Green
Thanks Mike would you have the speed healer switched with the cc so only on when selected
Post #881680 29th Jan 2021 10:18am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
you can do it two way and I've done both.
1. speedo healer - great you can program a A and B setting, so if you switch into your overdrive, if will use one setting while if you do not have the overdrive engaged, you can use the other setting. Technically, what you are doing with this is to reduce the pulses to fool the ecu to thinking the gear ratio is valid, ie the road spead vs the engine rpm. the moment you engage the overdrive, the rpm will drop, but the road speed is higher than what the ecu think its should be. so it doesn't not allow the cruise control to engage. Doing it this way, might be the preferred way for you as you can switch when you want the pulse reduction to kick in via the speedo healer. you might need the extra plug in switch for the speedo healer to work for the switching.
2. modify the valid gear ratio in the ECU map - this is more for those who have change the T-box ratio and cannot get the cruise control to engage in gear 5 due to the same thing that's happening above. If you know your way around how to remap the ECU, then this is definitely the easier way as you just need to use your calculator and not have to mess around with wires. Going this route also allows you to adjust the cruise control PID, or how hard it will accelerate when the speed falls below a certain value. The defender has migrated, leaving the owner behind.
Post #881734 29th Jan 2021 3:19pm
Bim
Post #881763 29th Jan 2021 5:21pm
Bim
[quote="achuakh"]you can do it two way and I've done both.
Thanks for that actuakh think I will go whith option 1 as this suits my driving style
As cc is only required for long motorway driving I would be in overdrive this will stop my leg from ceasing up
Laughing
Post #881768 29th Jan 2021 5:49pm
Wallywulpimuir
Australia
achuakh I am in Australia and have done similar to you with option 2 this resolves the issues very easily even with a Roamerdrive on a Defender
What I cant find in the ECU is the Cruise control PID so I can change the harshness with which the vehicle accelerates when the cruise control is on can you give me any advice
Wally
Post #939951 28th Jan 2022 10:27pm
djam1
2002 Defender 110 Td5 SW Alpine White
I am interested in this subject as well
Post #940102 29th Jan 2022 11:04pm
BP
2007 Defender 90 Td5 XS CSW Coniston Green
I went with the speedhealer option as well for my cruise/overdrive setup. Works really well.
Post #952341 12th May 2022 8:57am
Linds Hanson
4RF RDS wrote:
excossack wrote:
Digging up and old thread here...Do all TD5's support Cruise control ? Mine is a Jan 99' model.
FWIW... I have an 2000 MY and would love cruise as well but alas.... Its not cruise but this little mod made long distance driving a tad more comfortable by undoing one of the throttle springs. Its easier on the right leg.
You may find driving along bumpy tracks will induce kangarooing with a light throttle spring TD5's were prone to this at the best of times
Post #952390 12th May 2022 6:14pm
lightning
l wouldn't remove one spring completely, because if the other one ever fails you'll be stuck on full throttle.
You can make the pedal lighter by re drilling one of the spring locating holes so the spring still works but less strong.
Post #952394 12th May 2022 6:34pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
As I head into deeper into my Land Rover mid life crisis I seem to be awakening some of these posts?
Anyway, can anyone give me their latest experience of TD5 cruise control and how well it works.
Is it smooth or jolty in applying the power to maintain speed or an absolute joy that is a must have upgrade. I guess this all depends on the power and onboard weight.
I do a fair bit of motorway driving in mine, only 60mph most of the time but cruise would be nice.
The system I am weighing up is the one from empire tuning, if anyone can give feedback on that?
https://www.empiretuning.co.uk/product/emp...-play-kit/ 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #1031845 17th Apr 2024 12:28pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I use cruise in Disco2 TD5, and it works nice. Especially during long trips it is nice to have free legs. In Def TD5 the function is the same. I have only one reason, nut using it in Defender - I use Defender only for short trips. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1031853 17th Apr 2024 1:25pm
mrwoo
Thanks for that - just out of interest what RPM's does the Disco sit at when doing 60 and 70 mph or
equivalent KPH? 1964 Series IIA SWB Truck Cab - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1984 Series III CSW
2004 TD5 90 CSW
Post #1031871 17th Apr 2024 2:43pm
MadTom
I have manual transmission, bigger tires, slower gears in diffs and weight around 3200kg, so a bit non standard Discovery 2. Look on Ashcroft web, there is calculator. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1031889 17th Apr 2024 4:42pm
Page 5 of 5 <12345
