pdv
another powerloss topic... | |
hello
i had a problem when driving for a wile on the highway +- 110km/h constant en then give it a bid of throttle that it would go in to limp mode and turning on and off worked.
now i have changed following parts: radiator, thermostat, maf, map and did the injector seals (copper washers).
the problem has now gone from going in to limp to just cutting power but not like in limp mode. its more like a jojo effect power / no power for 5sec and back power for 5 sec... weird
i did not check the turbo actuator as it drives perfect on country roads even after the problem happening. but i have a noise from turbo side but i can only hear it from 80km/h and up and is not RPM related. its high pitched and sounds metallic to me.
i will also change the VCV as i have read here this could also give problems on highway.
someone who had this type of problems and noise ?
thanks
Tarcis
16th Apr 2024 4:11pm |
