Home > Technical > Defender Puma Starting woes... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
It’s usually a loose connection, either live or ground related.
Check the battery clamps are tight, check the grounding points are not loose and any other lives. Check the mega fuse on the live battery post is not loose. This is normally the reason behind these sporadic issues, and that’s why they can be temperamental. There is a lot of vibration in defenders through drivetrain, and everything else so component can come loose. Be especially cautious if you’ve recently had a clutch changed, as many components get disconnected and refitted during a change. And after that, they then can become loose creating problems that come and go which is difficult to nail down. I presume you have the fob synced ? As that will cut the engine if not due to immobiliser. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Apr 2024 5:30pm |
robbo22 Member Since: 21 Oct 2023 Location: Leistershire Posts: 23 |
Thanks for the reply!
Im going to check over the connections at the starter motor and battery this weekend. I know the clutch was changed last July but the fault only started once i changed the starter motor. My landy doesn’t have central locking. Its just a standard key blank. |
16th Apr 2024 12:14pm |
I take it you tested it before fitting and all was well presumably.
I was looking at the starter motor last week, a very fun (not!) place to put it to remove and replace and access. Typically Puma. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Apr 2024 4:09pm |
