![]() | Home > General & Technical (L663) > Driveline Disconnect |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3427 ![]() ![]() |
Defender has had intelligent all wheel drive since 21MY
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
It was introduced for 21MY
https://www.defender2.net/forum/post868528.html |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
did LR solve/fix the issue / alerts that were coming up stating the "only 2 wheel drive available",
a few reports in Australia of the system not applying 4/AWD, which was disconcerting if you are remote .. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
Yeah my first 90 had it, a couple of software updates solved the issue. 24MY 90 D250 HSE, Tasman Blue
ardevd Member Since: 04 Mar 2024 Location: Norway Posts: 43 ![]() ![]() |
Are you sure this is the same as “intelligent driveline disconnect” which means you can drive in RWD for enhanced efficiency? |
