![]() | Home > Td5 > Manual swap to automatic |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 212 ![]() ![]() ![]() |
Ashcroft transmission do a conversion kit using the ZF auto box from a Td5 discovery not cheap but it can be done 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
The Gribbin Member Since: 25 Mar 2022 Location: Tewkesbury Posts: 32 ![]() ![]() ![]() |
The best thing I have done to my Landy, so much more relaxed driving... supposed to be better off road, but I haven't tried that yet. I have a Stage 2 tune, that helps, with cruise control, happily sits at 70 mph on the motorway. Bit far for you, but Ashcroft did my conversion, looks factory... I'm sure you could get someone local to fit heir kit... recommend the larger torque converter. Enjoy! |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1662 ![]() ![]() ![]() |
As above Ashcroft’s do a complete kit and ships worldwide
https://ashcroft-transmissions.co.uk/produ...-auto-kit/ |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 512 ![]() ![]() ![]() |
My opinion is that it is without doubt the best modification to a defender which will transform the vehicle both on and off road, especially with some engine power upgrades at the same time.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2273 ![]() ![]() ![]() |
Time to fit an M57 and 6 speed auto then 😁 you won't look back.
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I second that. M57 with an auto box is the way forward. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 492 ![]() ![]() |
Even better with a 8HP 8 speed |
