Home > My Defender > What Did You Do In Your Defender Today |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
Replaced the drive belt with a new one. I think the squeak has now finally been cured. 1999 Defender TD5 110
31st Mar 2024 3:58pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
Steveww - The DIN cages are sharp too, many have been made more rigid and slimmer towards the locking aperture for that reason so they aren’t rattling.
But as I said they can have some sharp edges it be careful of as well<especially cheaper ones. JoolsB - Ah yes, the wipers job is a big one. I had the joys of that last year. I am relieved it’s over and not a job that is often required to be done! Excossack - Not too bad a job to do that one, they do make some noises. I saw an interesting article the other day regarding alternator whine and noises via audio system. (Which isn’t the issue you had I doubt, probably externally audible from itself. Anyway, the belt was creating static charges, and that was being mirrored upstream with every revolution, and that was causing static electric charges, pulses upstream, and back up to the audible system. I don’t know what vehicle it was or anything like that, but was interesting alll the Sam exit was in the States. The guy had tried all sorts to try and find it, checked everything but a new serpentine belt sorted it out. There wasn’t even any issue with the Alt, or any other component other that it was picking up static. I suppose a RF choke or ferrite ring or clip may have been useful though. Bearings can cause an issue too, but you never know hopefully that’s all good for you now. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
31st Mar 2024 4:48pm |
Thanks C90. Hopefully all solved now...Well until the next noise appears. Time will tell.
I will look into replacing the bearings in the pulleys. I think Geobloke has done this. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
31st Mar 2024 5:16pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 125 |
Avoiding the rain!
Window tints, leaking camshaft seal. New belt, tensioner, & idlers! Last edited by M94PUMA on 2nd Apr 2024 7:50pm. Edited 1 time in total |
2nd Apr 2024 4:18pm |
Looks good. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
2nd Apr 2024 5:15pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2081 |
I agree with Steve - looks very good 👍
Can’t help but have wheel envy |
2nd Apr 2024 5:43pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
2.4 2011 Puma. Up for the test this morning. Pass.
Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
4th Apr 2024 10:08am |
Proper job. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
4th Apr 2024 4:35pm |
The series three being 42 years of age is exempt (40 years of age makes the exemption kick in) thank God! It used to be a nightmare with the braking imbalance. Failed once on a braking imbalance of 7%. Stopped great but the technology was saying there was an imbalance. 1982 88" 2.25 diesel
4th Apr 2024 4:42pm |
Tidied up the rear end!
Crossmember cleaned down to metal and hit with buzzweld products. New mudflaps. Internal gwyn Lewis mud shields. All bolts replaced with stainless and tub to crossmember bolts used with correct grease to help prevent any corrosion. Click image to enlarge |
6th Apr 2024 4:36pm |
That looks splendid - a job very well done. I bet you feel a great sense of satisfaction.
Please cover your wheels up though as I keep getting very envious |
6th Apr 2024 5:19pm |
Thank you! - Will have to censor them out in future
6th Apr 2024 5:26pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1858 |
Very nice Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
6th Apr 2024 5:32pm |
80 mile round trip yesterday, never missed a beat.
Today took all the wheels off, greased the DM’s, all okay with those, none dry which is good and now re-lubed. Checked brake pads life also, plenty there. Noticed two of the pad springs on the front callipers, that one on each side out of each two per side, had managed to get into the brake pad aperture on the pins rather than sitting butt up against it. (It, being the pad and its aperture / hole). Managed to carefully tease them out and they then sat against the area they should do butt up against the brake pad backing, they are there to push the pads away from the disc, though even when new they aren’t that strong then they aren’t meant to be. With them like that, will mean the pads will sit close to the pad, perhaps a bit more than they should and add some drag and u wanted heat and thus a bit more fuel consumption for no good reason none of which would be great. Perhaps might be a good idea to fit new calliper pins and springs. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
7th Apr 2024 4:02pm |
