Home > Maintenance & Modifications > Rear forward facing seats in a 90 |
The Exmoor Trim seats will bolt straight in but are pretty expensive and also very close together, reportedly making access tricky.
Puma seats are less expensive (second hand) and are arguably the better solution in use, but are much more complicated to fit and often require the sourcing of many separate smaller parts, depending on how diligent the donor was. I would imagine that doing it with all new parts would be prohibitively expensive. Those are the pro's and con's but only you can decide which option will better suit your circumstances. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Sep 2017 12:16pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
....^^^ ... as a donor I would be very diligent ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
20th Sep 2017 12:46pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1035 |
The big downside of the Puma seats is the amount of space taken up when they're folded away. They're also a pain to remove and replace (who put the nut in the wheel arch?).
If only it were possible to have some seats similar the those in the Discovery. |
21st Sep 2017 6:46am |
soccerlaw Member Since: 01 Apr 2024 Location: los angeles Posts: 4 |
If you don’t want to cut the tub, I’ve seen several people install with spacers and some adjustment to the brackets. Has anybody here tried that approach?
2nd Apr 2024 9:58pm |
