![]() | Home > Puma (Tdci) > Puma 2.2 UltraGauge not reading values (intake temp, EGR) |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2281 ![]() ![]() |
Have you looked at the green coloured “Air charge sensor” on the metal pipe between the output of the intercooler and the inlet manifold, part number LR032216
That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor. Listed as part 8 on this diagram https://www.lrworkshop.com/diagrams/land-r...es_2.2tdci Re your other post on this issue Also IIRC another member had a similar issue with their 2.2 and was investigating whether the Carburettor Throttle Body, part 3 in the diagram, was sticking and not fully opening. PPS the EGR doing its chugging does not happen after every stop of the engine, but if it never happens then there is an issue. Normally an EGR issue will create a DTC. |
BrunoJ Member Since: 14 Sep 2019 Location: Stavanger Posts: 79 ![]() ![]() ![]() |
Thanks I'll check it.
On the 2.4 the air temp sensor is in the MAF. The 2.2 has two air temp sensors, one in the MAF, the other being the one I highlighted earlier in the pipe after the intercooler output. Your scan gauge may only be reading the MAF based one , that’s just a guess by the way.
On transit forums for the 2.2 engine we have there are several posts on the separate green sensor going faulty, especially after a cold spell or if it gets contaminated, resulting in similar problems to the ones you have had. A replacement is not expensive, a ford one being cheaper than a LR boxed one. So perhaps worth a try for circa £15. |
I just saw number of posts or screenshots with UltraGauge presenting InTake Air Temp correctly. Some of them are indeed in 2.4, but I believe also 2.2.
I still wonder - if temp sensor is not working correctly - what is the impact no how engine works? No errors nor some odd engine behaviour? Looks like I use the car like that last few years... |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 592 ![]() ![]() ![]() |
I am using an Ultra Gauge on my 2.2 TDCi.
I have it set up to show: Ambient temp Engine temp Oil temp Cat temp EGR demand % Battery voltage All working just fine. |
I'm quite surprised about the solution for my problem. Some magic happened
![]() As discussed in separate thread, I had some doubts about MAF, then find out I had incorrect one installed (from older MY). I managed to replace it with new, proper part and... bingo! I have now both Intake Air Temp and Ambient temp (both stays with -40 before). More over - I have now partially both ERG flow and error readings. Partially, because they still jump from time to time into 0/-100%, which looks like loosing the connection/reading in some situation. I'm surprised, because that old MAF somehow introduced the confusion in electric installation and reading the values on ODB2. There is also other option - due to incorrect values of temperature from previous MAF, EGR stays always opened or closed. Which could actually cause some of my previous issues with it (P0405 error). I thinks it is less probable, but... It is kind of funny, because while investigating issues with EGR, LR service recommends to ... disconnect my UG as it potentially cause the issue with ODB and messages. Now it seems to be confirmed, the MAF could be the troublemaker. Less funny - I was driving like that last 4 years, having number or services and inspections, and found out the MAF could be failure and it is not correct for that engine. Well... Good to have it solved, I'm really glad. I have to observe the EGR values. First ride I had impression almost half of time EGR flow was 0 and EGR errors -100%. After 3 city rides, I still see 0/-100, but much rarely than before. Something starts working finally? Also what surprised me - reading the forum I got impression the intake air temp is rather read from separate temperature sensor (green element). Why it come back into ultragauge, after replacement of MAF? The same for ambient temp? I do not see proper correlation here. When weather permits, I'll try to inspect the connector to EGR, or - if you have any suggestion elsewhere. |
