Home > Td5 > can't get the temp up on my Td5 |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 205 |
Did you test the Thermostat before fitting as I bought a genuine LR one 2 years ago that was faulty from the start and had to replace it albeit on my D2 at the time 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
1st Apr 2024 8:24am |
I am going to ask the question... The gauge may not move but is the engine getting to temperature? Can you get a laser thermometer onto the hoses/block to test.
Just wondering if it isn't a bad earth to the gauge, a duff sensor or broken wire to the sensor?! But it could be the new thermostat too. If it would help I am happy to pop out and measure the voltage to the sensor, I believe the sensor has a range from 0-5v. |
1st Apr 2024 10:03am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1104 |
Everything is possible but before fitting I checked the thermostat and it was closed. If it was not to open it would overheat no? Click image to enlarge Click image to enlarge Click image to enlarge I can check the temp with nanocom, and i do have an infrared thermometer somewhere. Will do that first |
1st Apr 2024 2:10pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8133 |
does the heater work as normal? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1st Apr 2024 6:00pm |
