Home > Td5 > Snorkel & Wading and sealed air systems in TD5s
Page 2 of 2 <12
geobloke
As above. I ran a Safari scoop top for more than 10 years on various vehicles. The fitment height of the top is critical and it is absolutely worth removing the top periodically as the drainage slots can block with debris and insects. The only troubles I ever had were with the scoop facing forwards during heavy snow or rain fall which just overwhelmed the Safari drainage slots. Yes the rain in Wales is that torrential at times. At which point you have to get out in said weather and reverse the direction of the scoop. So keep a screwdriver in the cubby box.
I replaced the safari RAI when I had the roll cage fitted as they are not compatible. Rebuilt the intake system with what was a PandP RAI and made the rest of the inner pipework myself. The top is a generic mushroom cyclonic thing with a gutter and it works brilliantly. Miffy's air filter has never been wet and is barely dusty when checked. You can see it below.
As has been mentioned above, the key is to not trust foam gaskets, a smear of RTV is essential between joints.
Post #1029805 30th Mar 2024 9:17am
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Well after re-sealing it has now passed a 20 minute hose test.... now to chose what hat to wear
Post #1029858 30th Mar 2024 9:00pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Thumbs Up 👏🏻👏🏻👏🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1029879 31st Mar 2024 1:57am
Page 2 of 2 <12
