Home > Puma (Tdci) > (Hopefully) Simple Heater/Aircon Trim Question
Keyser Soze
Switzerland 2012 Defender 110 Puma 2.2 DCPU Keswick Green
I have the entire interior apart and am replacing all the hardware plus any plastic I can swap to aluminium. One little thing has me stumped and I am trying not to break the backing plastic.
These two plastic bits in black for the AC level and the exterior/interior recirculation, what's the trick in getting them off? Don't see clear clips, they don't pop off on pull, and I can't see any adhesive. I don't want to damage the green plastic below. Any easy tricks? Help!
Post #1028912 21st Mar 2024 8:04pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Mine just fell off when I took the dash apart, if it helps, the green plastic is part of the slider.
Post #1029316 25th Mar 2024 10:37pm
Keyser Soze
Thanks for the help, I just had to take a small screwdriver and break the edges. You have to be careful as the sliders are the green glass (if you're changing them to aluminium like I was - you'd need to find unbroken bits).
Thanks for the help!
Post #1029671 28th Mar 2024 8:44pm
