Home > P400e Area (L663) > predictive energy optimization (peo) with Apple CarPlay?
ardevd
Norway
Land Rover PHEVs have a feature called “predictive energy optimization” that makes use of routing data from the navigation system to optimize the use of EV in hybrid mode. However, does anyone know if this only works when the built in navigation system is used or will it work with Apple CarPlay too?
Post #1029550 27th Mar 2024 9:14pm
TexasRover
Is the same feature not available on Google maps?
Bit gimmicky greenwashing. The most efficient journey is the journey not taken.
Post #1029564 28th Mar 2024 4:36am
ardevd
Norway
The point of the system is to optimize the use of EV mode. So if the system knows you’ll be entering an urban area it will save energy and use EV mode there for example. But I presume it relies on Pivi Pro map information and it won’t necessarily work if you’re using Apple Maps or Google Maps for routing. Hence my question.
Post #1029570 28th Mar 2024 6:33am
