Home > Maintenance & Modifications > Defender 90 sunroof seal?
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
I have a drip from my factory fitted sunroof after it has rained. I’ve cleaned the glass part and smeared silicone on the sealing rubber but still get the drip.
Does the seal simply pull out of the channel where it sits or is it clamped in by the sunroof surround. The only video I could find on YouTube shows a guy replacing the seal on a Discovery 2. Is this the same procedure for a Defender?
Jim
Post #1029350 26th Mar 2024 12:51pm
geobloke
How irritating. Two things worth checking before ripping out the seal.
1) Check that the screw fitting seals are not what is leaking.
2) remove the sunroof glass by unclipping the turn buckle and hinging the glass forwards out of the plastic slots. It is common that the metal curved part of the hinges rust and do not retract properly into their slots. This raises the front of the sun roof glass a little but and preventing a good seal.
Post #1029366 26th Mar 2024 3:20pm
jim4244
Thanks geobloke
I’ve done that and cleaned the seal and the glass to ensure good glass to seal contact. I’ve also replaced the small gaskets on the head of the 2 feet that hold the glass in place at the front.
There’s a seal on eBay for £72 which I’m looking at. I just don’t want to strip the entire sunroof down only to find that it was a case of pulling out the old seal and pushing in the new one.
Jim
Post #1029375 26th Mar 2024 4:56pm
geobloke
Good job Thumbs Up Ah ha just found that John has posted a thread about getting the seal out, here you go https://www.defender2.net/forum/post828599.html
Appears it is a prize out job not a complete sunroof removal job.
Post #1029379 26th Mar 2024 5:05pm
spudfan
Ireland
Would the drain tube be blocked? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1029560 27th Mar 2024 11:34pm
Oldowner
They don’t have drain tubes.
Water can also leak in between the outer frame and the roof skin - once the glass is removed the sunroof frame can be unscrewed and removed entirely, allowing the frame to be sealed to the roof skin. I did this in 2014 and along with a new glass to frame seal and it has been leak free ever since.
Land Rover’s permanent cure was to delete the sunroof option in later years.
Post #1029575 28th Mar 2024 7:34am
